I want the section smooth where fillet-1 is situated.If i use a fillet >2mm then it deletes all the part except the fillet.I was hoping to have a fillet 15mm or a similiar shape where the hump is more rounder.Do i need to re-model using other ways because i cannot get the fillet to work
J.S
Inv.2014
Solved by JDMather. Go to Solution.
Solution for this part was covered here a couple of months ago - a search might turn up the thread.
Sketch 2 is not constrained?
I believe that part of the solution is to not loft as a "pipe" but to Shell after the outside geometry is created.
Attached is one of several proposed "solutions".
There are fillet solutions as well.
Did this Loft solution work for you?
Yes thank you.The Loft worked well
I would for learning purposes like to see the fillets solution as well if possible
Regards
J.S
Note also that with the Loft solution you can control the weight of the tangency.
