Inventor Forum
Fillet Command Crashing Program
3 REPLIES 3
634 Views, 3 Replies
Anyone else having problems when trying to create a fillet, and it crashes the program? In my case, I'm trying to create a .004" fillet along edges created using an extruded/cut spline. It tells me the radius cannot be created - try using a smaller radius... and then when I hit either edit or cancel, the program crashes.
3 REPLIES 3
oomclintmidas
Your graphics card driver is more than likely in need of some attention. check ou this FAQ on the CADlinecommunity http://www.cadlinecommunity.co.uk/FAQs/FAQ.aspx?ScoId=93db7864-b66c-43b3-94b7-150118f17b9b&returnTo=... - you will need to register with the site, but registration is free
JDMather
Attach the file that exhibits this behavior here for others to test on their machines.
Hochenauer
Please attach or email the file that shows the problem to me - along with the version of Inventor you are using.
Gerald
Gerald Hochenauer(gerald.hochenauer@autodesk.com)
Inventor Principal Software Engineer
Manufacturing Group
Autodesk, Inc.
Gerald Hochenauer
Senior Principal Engineer, Inventor
Autodesk, Inc.
