I have been asked to change some of the default weld settings within the weldment template, i.e. set groove weld to full face full face, set the fillet weld to 6x6. so that when we do a new weldment these things are already set, have hunted high and low on here, through google, autodesk knowledge base for inventor but havent found anything, not sure if havent put the right keywords in or that it just isnt possible to do.
Cheers
Blu
Most defaults can't be set. My grudge is with sheetmetal, the defaults there are garbage. I's an area where Inventor really falls short.
I tested having a fillet weld existing in a weldment template, but was unable to modify the default values or settings in the fillet weld dialogue. There doesn't appear to be exposed settings to modify these default values.
I logged an enhancement request on behalf of this post.
