Does anyone know if there is a commandt to fill in a little gap of missing material when you extrude one surface at the angle to the other. It's easy when it's a flat surface to just extrude in the othe direction, but with 3D loft it's not as much fun. See pic attached.
Thanx
William
Solved by rdyson. Go to Solution.
Can you not open the lofted part in the assembly, move the bottom face so it projects into the other part, place a workplane on the face of the part it is to meet, then split it using the plane?
Hi feldwill,
The Thicken/Offset tool can often be used to fix these gaps. Just select the face on the underside of the feature and thicknen it a bit. It might not work for your part ( I can't really tell) but it's something to try.
I hope this helps.
Curtis
William,
Under the model tab see if this command will work for you.
If not I would look at some of the other surfacing commands.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
In addition to Scott and Curtis' advise, you might also try Surface<Delete Face with the Heal setting. Can't really tell from the image what the geometry really is.
Swhite and Curtis_Waguespack the problem with Thicken/Offset or moving that surface is that it creates 2 surfaces on the face of the blade and then I can not put a fillet there (It creates plane normal to the one selected and doesn’t follow the 3D spline of the blade). Rdyson- delete Surface/Heal sounds noble but it doesn’t want to do what it sounds it should.
I have attached an ipt if anyone wants to play with it and see if there is a trick up there sleeve or may be I’m using wrong modeling technique.
William
Actually, delete face will work in this case. But I think you need to work on your modeling some.
I quickly deleted a bunch of things from the sketch for proprietary reasons, thats why it looks messy.
Hey, can you save that file compatible with Inv. 2012, Im getting an error, I think you are using 2013.
Regards
W
You should always indicate you version unless on the latest and even then it's not a bad idea.
I did a revolve cut to create a common surface and then the delte face.
Notice the i in circles - you have other problems.
Another technique that might have worked (I didn't try it with your geometry) is to Extend the surface before Thicken so that it penetrates down further into the existing solid.
Often, you should do the complex geometry first a bit larger than desired finished size then trim it back - just like out on the shop floor with real parts and then do the simple geometry like Revolve.
