Inventor Forum
file type to open
7 REPLIES 7
Message 1 of 8
Dferr34
381 Views, 7 Replies
file type to open
Is there a way to setup custom files when opening? I mean, like file types to open. It is normally set to iam,idw,dwg,ipt. Is there a way to add pdf with those so I don't have to use all files to see the pdfs.
7 REPLIES 7
Message 2 of 8
mdavis22569
in reply to: Dferr34
I'm confused ... you want to open a PDF in Inventor? That's not possible... are you talking about doing it in Windows and open PDF's always with a pdf viewer?
Mike Davis
Message 3 of 8
Dferr34
in reply to: mdavis22569
No, I don't want to open it in inventor. I just want to be able to see the file. so I don't need to go into windows. I know I can do this by viewing all files.
Message 4 of 8
Curtis_Waguespack
Hi Dferr34,
I don't know of any way to modify the default Open dialog. So I think you're likely out of luck there. Using the All Files filter is likely the best bet.
But here is an iLogic snippet that will show Inventor files and PDF files in a custom Open dialog box. I doubt that's what you're looking for though.
http://inventortrenches.blogspot.com/2012/01/creating-basic-ilogic-rule-with-event.html
I hope this helps.
Curtis
Dim oFileDlg As inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
oFileDlg.Filter = _
"File Types (*.idw, *.dwg, *.iam, *.ipt, *.pdf)" & _
"|*.idw;*.dwg;*.iam;*.ipt;*.pdf"
oFileDlg.DialogTitle = "Select a File"
oFileDlg.InitialDirectory = ThisDoc.Path
oFileDlg.CancelError = True
On Error Resume Next
oFileDlg.ShowOpen()
If Err.Number <> 0 Then
ElseIf oFileDlg.FileName <> "" Then
oDoc = ThisApplication.Documents.Open(oFileDlg.FileName, True)
End If
Message 5 of 8
mrattray
I think you're refering to this:
There's no way to modify this dialog. You're stuck changing the filter to all files. Sorry.
Mike (not Matt) Rattray
Message 6 of 8
mdavis22569
You want a view all file types ....all the time ... Hmmm Like Curtis was saying you'll probably need an ilogic that would be open ..but show all
Mike Davis
Message 7 of 8
ampster401
instead of adjusting Files of type to All Files, just type *.pdf in the file name field and hit your enter key.
Besides the OldVersions folder (if present), you will only see pdf's.
HTH
Message 8 of 8
Dferr34
in reply to: mrattray
okay, thanks.
