Inventor Forum
File selection quirks, IV2009SP2 Pro 64 bit on Vista SP2, latest updates
8 REPLIES 8
Message 1 of 9
rschader
235 Views, 8 Replies
I have a PC running the aforementioned versions of the software, and found a weird quirk that is probably some setting somewhere to fix it:
In many of the File Dialogs, for example Place Component, I will scroll to where I can see the filename and then click on it, but the click only highlights it, it doesn't place the file in the Open box down near the OK button. If I select another file after that, it does place right and I can then re-click the file I want, so by current workaround is to click the wrong file first, then the right file, instead of right=wrong-right, now it is just wrong-right, but that's still ONE click extra that I don't want!
Additionally, this install of Inventor crashes to desktop trying to IMPORT any foreign filetypes. My UAC is off and I am the administrator. I'm only seeing this on the Vista 64 box with IV2009SP2. Any one else see this problem? Virus scanner is AVG9, turned off resident shield during install too.
Bob S.
8 REPLIES 8
Message 2 of 9
in reply to: rschader
I am running almost identical down to the AVG9 with UAC disabled. No
problems at all with the system or with what you described.
IV2010-Pro-sp1
Vista Business 64bit Sp2
Core i7 950 @ 3.07Ghz
12Gb DDR3-1600, 4 x 60 Gb SSD - RAID0
Quadro FX3800 - 191.00
SpacePilot 3.8.1 / 6.8.1
AVG9.0
"rschader" wrote in message news:6303607@discussion.autodesk.com...
too.
Bob S.
Message 3 of 9
Check to make sure you have all the latest Microsoft patches & updates as
well as any Inventor hot-fixes/SP's
IV2010-Pro-sp1
AVG9.0
"Blair Stunder" wrote in message
news:6303656@discussion.autodesk.com...
IV2010-Pro-sp1
AVG9.0
too.
Bob S.
Message 4 of 9
I have a Vista 64 Service Pack 2 system (Avira AntiVir)running that does
not have this issue. I do have a few other quirks, like often having to
pick shortcuts twice to get them working.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
http://teknigroup.com
Message 5 of 9
nbradbury
I had vista and now I have Win7 and I had and still have the same behavior.
N-
Message 6 of 9
kellings
This issue has been confirmed by Autodesk. Last I heard, they were investigating it.
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Message 7 of 9
jrapert
Same problem here.
Also the file pointer does not go back to previously selected file in the Open window.
Dell M6400 Covet
Windows 7 Ultimate 64-bit.
12 GB RAM
320 GB HD
Nvidia Quadro FX 3700M 1 GB
Inventor 2010 Suite SP1
Message 8 of 9
Same here. A real pain.
Inventor 2010 SP1
Dell T3500
Windows 7 x64
Message 9 of 9
Has anyone heard of a solution to this issue yet? I have Inventer 2009 on Windows 7 (freshly installed Windows 7) with all service packs and updates. I have this same issue.
