When I rename a part, the iproperties field under project>part number does not change. If there is a drawing for the part, the part number in the drawing reflects the old part number.
Can I tell inventor to rename the part automatically to the file name as seen in windows explorer?
Can I set it to rename automatically in the tree in an assembly environment?
I'm using Inventor 2013.
Thanks for reading.
Solved by mcgyvr. Go to Solution.
Solved by Mark_Wigan. Go to Solution.
hi
if you rename the part in windows explorer say, then at the same time edit the iProperties (can be done RMB in windows explorer as well while you are there).
but, alternatively if you are working in an assembly, then you can either just do an open, "save as" & then replace sequence on the part or better if you do a "save and replace" on the part which will copy, name and replace on the part you are needing to change the name of.
in these you will have the old part still that you can choose to delete after or overwrite with another file later if you want to.
you can also use design assistant to rename your parts, whether individually or en mass. this can maintain links, copy / replace etc etc.
just pick the method that suits your specific needs.
How are you renaming parts?
Is this a content center part? (or was it at one time) There was a bug a few years ago that was doing this.. I "thought" it was fixed for everything but content center parts.
If you have vault, and rename there, during the rename process in the dialog window there is an "Update"
selection box. If you check that the property will update under the project tab inside of the properties.
You listed a few methods that should work. Save and replace looks like the best one.
I do not have Vault installed, so renaming files "en masse" with design assistant is not an option from what I understand.
Would that be correct?
Thanks.
@Anonymous.ind wrote:I was renaming parts in explorer, (not content center parts).
boom..there is the problem... rename in Inventor.
Boom!
I don't follow you.
You mean I should hit >file>open and rename the files in the window?
Please clarify. Thanks.
No. Design Assistant is an alternative if you are not running Vault.
Use Design Assistant. Do not use Windows Explorer as WE has no knowledge of the hyperlinks Inventor creates between Inventor files.
