Inventor Forum
file check out problem when saving
14 REPLIES 14
Message 1 of 15
413 Views, 14 Replies
I can't seem to get multi user to work without Inventor wanting to automatically check out a file when I save it. I open up an assembly file, do some changes and then click save. I get a dialog box showing the assembly file name, its file status and a row listing either "no" or "checkout/save". I just want to save. I don't want it to checkout the file. I just want to save and close. I have tried it in both "shared" and "semi-isolated" modes and I cannot get it to do just a save. Prior versions would ask me if I wished to reserve files and I would tell it no and move on. R6 is not giving me a choice. I have ended up disabling the whole multi-user scheme until I can get this resolved.
14 REPLIES 14
Message 2 of 15
It won't let you modify (which means save) a file unless it is checked out
to you. I believe it has to be this way, otherwise another user could
modify and save the file while you are modifying and saving the file.
Which is the purpose of a multi-user environment.
Cory McConnell
BJ Pipeline Inspection
"guzie" wrote in message
news:f126f0c.-1@WebX.maYIadrTaRb...
Message 3 of 15
I understand the principle. Something just doesn't seem right though. The checkout should be in the beginning when you first open the file and choose to edit it and not the end. It always used to work that way when we would get the reserve message. Now its like I am checking out a book that I just got done reading. I am just trying to put it back, not check it out. The checkout needs to be in the beginning so that anyone accessing the file after I do will be aware that I am editing it. What good is checking out when I am just saving and then closing the file? Now it sits as checked out on the network but I am already done with it. To clear the checkout I need to open it and go through the check in process. Then I try to save and it wants to check it out again!!!!! Argh. Just trying to clear a checkout causes another one. Its a piece of garbage this way. The old method worked fine. Now it is screwed up.
Message 4 of 15
You ARE supposed to checkout the file in the
beginning.  Change the browser to File Status by clicking the arrow next to
"Model" and checkout the file before you make any edits to it.  Then when
you save it, the modified version is saved in your Workspace.  It is then
copied back to the shared location after you check it back in.
I
up.
Message 5 of 15
I highly recommend you read the DOC file about
Project Management and Collaborative Design on the AIS6 CD.
I
up.
Message 6 of 15
I know all about that area and I have checked out the document. I have a hard copy of it right here. I have read it all. I have been with Inventor since pre R1 stuff so the whole file reserving process is not new to me. It actually only is supposed to copy the file to my workspace if I run in semi-isolated mode. I have it set in shared mode. What I am saying is that it is flawed. An example would be to open a assembly file and check out several parts. Do a few changes in the main assembly and then save. You will end up with the parts you selected and the assembly itself checked out. Close it and re-open it. Now check the files back in including the assembly. Everything is fine until you go and save again. It wants to checkout that same assembly that you just checked in. There isn't a way to check them all in and then just save without it adding another checkout. In the past I had the option to reserve a file or not. I was not forced to do so at the save. I am stuck too. I already have some files in the older versions that are currently flagged reserve. I cannot clear their status without running multi-user on and running with it on brings out this new flaw where I keep getting files checked out at save time. I can't win for losing.
Message 7 of 15
Is there a reason you're not using the preferred
Semi-Isolated environment?  The Shared mode is really only there in
Inventor 6 for backward-compatibility's sake.
I
win for losing.
Message 8 of 15
Because we do not want to copy data to our local drives for changes. All work is done on the network drive.
Message 9 of 15
Kev
I see no reason whay a semi-isolated cant have the local work areas also on
the server but in user specified designation.
- drew
Drew Fulford B.A.Sc. Systems Engineer
Solid Caddgroup Inc. Burlington, Ontario
Tel: (905)331-9670, Fax: (905)331-7280
Corporate: http://www.solidcadcam.com/
Member of the Autodesk Discussion Forum Moderator Program
Visit my MCAD website @ http://www.mymcad.com/
news:f126f0c.6@WebX.maYIadrTaRb...
Message 10 of 15
We can but our company still does not allow files to be copied to other locations for editing purposes. They need to stay where they are originally located so that is why the shared mode needs to be used. Either way the checkout/checkin process now sucks. Either way I still cannot just do a simple save without having the checkout applied. So how in the heck do I check in files and save without it re-applying the checkout? Evidently I have you guys stumped because you are focusing on whether or not I am running in semi-isolated mode or not. That doesn't matter. Both modes have the same issue. How do I just save without applying the stupid checkout? What a piece of junk this new mode is.
Message 11 of 15
I'm not sure if you're following these steps (it
doesn't sound like it), but this is the correct workflow.
1) Open the file (we'll say it's an
assembly).
2) Switch the browser over to File Status.
Check-out the assembly and any parts you wish to modify.  You now have
exclusive modify rights to this file.
3) Make the necessary modifications.
4) Save the file(s).
5) Switch the browser over to File Status
again.  Check-in the file(s) that have been modified.
6) Close the assembly and Inventor should not ask
you to check anything out.
We
is.
Message 12 of 15
That's the whole point of this system. You can not
just save, since you do not have exclusive rights to the document. Someone else
could be editting the same part at the same time. One of you will overwrite the
other. You should check-out the documents when opened!  However, to go
along with what you are saying, this should be an option when opening a drawing,
not after it's already open. Even a simple check-box would do the
trick.
We
is.
Message 13 of 15
Also, if you are editting the assembly, why aren't
you checking out the assembly? You should check out the whole tree if you are
changing something that will affect the whole assembly. Again, this is because
someone else might be making a change that could affect you, or vice-versa, and
you will screw each other up. This is the point of this system. It's not billed
as a true PDM system, only an aid. Quit saying it sucks, and learn how to
benifit from it.
We
is.
Message 14 of 15
Agreed.  I would argue that the
methodology in prior releases was flawed, not Inventor 6's.
Quit saying it sucks, and learn how to benifit
from it.
Message 15 of 15
Now I see where I am going wrong. I tried everything you listed but after check in I was thinking I had to save the assembly to retain the check in state. Just doing the check in and closing worked. I open the same assembly back up and the stuff is still checked in. Its confusing because any change you normally make in an assembly needs to be saved to have it stay. Thanks for the clarification.
