Inventor General Discussion
0 Kudos
Post 1 of 7
Accepted Solution
figure eight spring
256 Views, 6 Replies
02-08-2013 06:17 AM
Need to design a part and the best way to  describe it would be a figure eight spring. Any ideas?
Hi randyp,
Attached is an example file that you can look at. Note there might be other methods to use as well (such as something like this link). You didn't mention the version of Inventor you're using so hopefully you can open this Inventor 2010 version (that's the oldest version I have installed).
You might also see JDMather's knot tutorial for more on the general technique:
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%2011%20Tutorial%207.pdf
I hope this helps.
Curtis
*Expert Elite*
889 Kudos
Post 2 of 7
Re: figure eight spring
02-08-2013 06:20 AM in reply to: randyp
That doesn't make any sense to me. Can you post your attempted part and maybe a picture or sketch of what you hope to achieve?
Mike (not Matt) Rattray
*Expert Elite*
2,121 Kudos
Post 3 of 7
02-08-2013 06:21 AM in reply to: randyp
I think this problem (or very similar problem) has been discussed here many times in the past, but just to be sure - can you post an image or url to something similar?
Have you made an attempt yet - if so can you attach the ipt file here?
Also - what version of Inventor did you say you are using?
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
0 Kudos
Post 4 of 7
02-08-2013 06:39 AM in reply to: mrattray
I have no drawing or sketch at this time it is in a thought process. Maybe this will make more sense - Look at it like a figure eight race track where part of the track goes under the other Thanks Randy
0 Kudos
Post 5 of 7
02-08-2013 06:48 AM in reply to: JDMather
No attempt as of yet and not sure how get it started. Another way to describe it would be to look at it if it was a figure eight race track where one part of the track would go under the other Thanks Randy
*Expert Elite*
1,702 Kudos
Post 6 of 7
02-08-2013 07:08 AM in reply to: randyp
Hi randyp,
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
0 Kudos
Post 7 of 7
02-08-2013 07:20 AM in reply to: Curtis_Waguespack
version 2013
I will take that idea and run with it
Post to the Community
New Post
