Inventor Forum
Feature Recognition 2012 not working
12 REPLIES 12
Message 1 of 13
1618 Views, 12 Replies
This is issue in Autodesk Inventor Professional 2012. After installing Feature Recognition x64 bit 2012, its installing successfully. But its not showing in Add-in manager and is not working. So kindly suggest me in this regard.
Prasanth Pakalapati
12 REPLIES 12
Message 2 of 13
mercerc
You may be better off posting this to the Labs email site. But in reviewing this I did notice that there are different versions of the feature recognition tool. I loaded the 2012 version and it shows in my add-ins. Another thing would be to do the installation as Local Administrator or run as Administrator
Charlie M
Inventor Product Support Specialist
Message 3 of 13
MariaManuela
Hi.
Have you tried the feature recognition that already inside Autodesk Fusion?
Asidek Consultant Specialist
www.asidek.es
Message 4 of 13
JDMather
I just installed on 2 32-bit machines.
On one it works - on the other - nothing?
Message 5 of 13
3DAli
in reply to: JDMather
Hey Guys,
I think I got it to work after spending a good 3 hours on it! its simple, how stupid I was not think about it sooner, all you need to do is manually register the dll file which is located under inventor 2012\bin\featurerecognition.dll through regsvr32.exe command. how? ok, start menu, run, punch in cmd and enter, then navigate to c:\program files\autodesk\inventor 2012\bin\ and then type regsvr32 featurerecognition.dll. then it should work. make sure inventor is not running when you do this.
trust it helps
Sincerely
Ali
Signature_Small
Message 6 of 13
in reply to: 3DAli
@3DAli:
You are a real life saver! Manually registering the dll works like a charm. Many thanks!
Best Regards,
Maurice
ALUMATZEEMAN
Message 7 of 13
3DAli
Youre very welcome Maurice, I'm glad it helped Smiley Wink
Cheers
Ali
Signature_Small
Message 8 of 13
DPLOWMAN5757
I have manually register the .DLL file and it shows up in the Add-in manager, but it does not show up under any of the tabs. How do I access the feature? Please help
Message 9 of 13
JDMather
in reply to: DPLOWMAN5757
I don't see any solid features in your screen capture - only a 3D sketch?
Expand the feature tree here
Message 10 of 13
DPLOWMAN5757
My problem is that I was sent a *IGS file, which comes in as wires, but I would like to convert it into a solid *.IPT
Message 11 of 13
JDMather
Attach the original IGES file here.
You might read this (older) document.
http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf
Message 12 of 13
DPLOWMAN5757
here is the file I want to convert to a solid *.IPT part
Message 13 of 13
JDMather
Either the SolidWorks user doesn't know what he was doing or wanted to protect intellectual property ( I would guess the former and this file doesn't do the latter).
It should take you about 5-10 minutes to create the solid geometry.
Simply project to 2D sketches and Extrude.
