Inventor General Discussion
prasanthpakalapati
Message 1 of 13 (920 Views)
Feature Recognition 2012 not working
920 Views, 12 Replies
11-02-2011 05:02 AM
This is issue in Autodesk Inventor Professional 2012. After installing Feature Recognition x64 bit 2012, its installing successfully. But its not showing in Add-in manager and is not working. So kindly suggest me in this regard.
Prasanth Pakalapati
Product Support
mercerc
Message 2 of 13 (900 Views)
Re: Feature Recognition 2012 not working
11-03-2011 07:56 AM in reply to: prasanthpakalapati
You may be better off posting this to the Labs email site. But in reviewing this I did notice that there are different versions of the feature recognition tool. I loaded the 2012 version and it shows in my add-ins. Another thing would be to do the installation as Local Administrator or run as Administrator
MariaManuela
Message 3 of 13 (894 Views)
11-03-2011 08:11 AM in reply to: prasanthpakalapati
Hi.
Have you tried the feature recognition that already inside Autodesk Fusion?
Maria Manuela Pinho
Application Specialist
Cadtech / Asidek - Autodesk Gold Partner
Autodesk Inventor Professional 2015 | Lenovo W520
JDMather
Message 4 of 13 (885 Views)
11-03-2011 09:13 AM in reply to: prasanthpakalapati
I just installed on 2 32-bit machines.
On one it works - on the other - nothing?
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Valued Contributor
3DAli
Message 5 of 13 (815 Views)
12-08-2011 08:24 AM in reply to: JDMather
Hey Guys,
I think I got it to work after spending a good 3 hours on it! its simple, how stupid I was not think about it sooner, all you need to do is manually register the dll file which is located under inventor 2012\bin\featurerecognition.dll through regsvr32.exe command. how? ok, start menu, run, punch in cmd and enter, then navigate to c:\program files\autodesk\inventor 2012\bin\ and then type regsvr32 featurerecognition.dll. then it should work. make sure inventor is not running when you do this.
trust it helps
Sincerely
Ali
Warm Regards
New Member
info
Message 6 of 13 (682 Views)
03-09-2012 02:55 AM in reply to: 3DAli
@3DAli:
You are a real life saver! Manually registering the dll works like a charm. Many thanks!
Best Regards,
Maurice
ALUMATZEEMAN
Valued Contributor
3DAli
Message 7 of 13 (662 Views)
03-11-2012 04:30 PM in reply to: info
Youre very welcome Maurice, I'm glad it helped :smileywink:
Cheers
Ali
Warm Regards
Active Member
DPLOWMAN5757
Message 8 of 13 (462 Views)
10-17-2012 11:25 AM in reply to: prasanthpakalapati
I have manually register the .DLL file and it shows up in the Add-in manager, but it does not show up under any of the tabs. How do I access the feature? Please help
JDMather
Message 9 of 13 (449 Views)
10-17-2012 11:57 AM in reply to: DPLOWMAN5757
I don't see any solid features in your screen capture - only a 3D sketch?
Expand the feature tree here
Active Member
DPLOWMAN5757
Message 10 of 13 (441 Views)
10-17-2012 12:05 PM in reply to: JDMather
My problem is that I was sent a *IGS file, which comes in as wires, but I would like to convert it into a solid *.IPT
