I'm new to inventor!
I need to repeat a hole inside a circumference and don't know:
1. How to define a path that is exactly like the circumference, inside the geometry face, and with defined distance from sides
2. How to repeat a hole along a path which is neither circular nor rectangular
If to use sweep, I must define a path so this return me to fist problem, creating closed loop. Also, I'm not sure that sweep tool is for hole repeating at all. Standard patterning tools won't work here, hope there is a way to define general path.
What is the right technique for this matter please? If my description is not clear (I'm non native with English) please open the attached image.
Thank you in advance.
Solved by JDMather. Go to Solution.
@Anonymous wrote:Hi,
1. Project Geometry and Offset.
2. Curve driven pattern (you might read this document http://home.pct.edu/~jmather/skillsusa%20university.pdf )
Thank you for fast and kind responses, by reading pdf I still can't figure out the answer.
I attached the ipt file. I'm working on a 1.5m height wooden robot. Using Inventor started at the middle of the work. First I worked with CamBam and simply designed to machine. I turned to Inventor because I need to machine the head, which has a plate with holes around it, then columns that would be inserted in the holes build up the face.
In the ipt file, the plate is presented. It has the column hole. I don't know how to command inventor, so that these columns' holes repeat in equal distances with regard to the circumference lines, which are both arc and straight lines.
I would greatly appreciate your help.
Best Regards.
@Anonymous wrote:.... by reading pdf I still can't figure out the answer.
Go back and read it again. Your Sketch1 is not constrained or making use of obvious symmetry about the origin. You should master sketch constraints before moving on to curve driven patterns.
I also noticed that you have extra lines over lines and extra dimensions that are not needed if you use symmetry.
(Side note) Evidence why Fusion should not be a released product.
Is something like this what you are after (see attached image).
Thanks for instructions,
Which one? in last point I can't find any attachments unfortunately.
I'm a software engineer and by logic of life happened that I must finish a skeleton of a simple robot for game purposes.
Robot description:
The only motion capability is on left hand containing only 5 servo motors, 3 joints, the right hand just keeps a tray containing a ball. The actual part to be made is a head, containing a tablet pc. The sketch I sent was to depict my abstract question, I'll try to formulate it better now:
Question: is it possible to pattern a hole a long the circumference of a non-symmetric object please?
Answer (guessed): the circumference must be copied, scaled down inside same sketch to give path, then use sweep.
Not sure if the answer worsk: don't know the method/tools to perform suggested operation.
I attach the image of robot skeleton under work (that must this week get the head and then be covered by leather), to hopefully get your general suggestions of forum Gurus too.
I only hope I'm clear with my writing, I apologize if non accurate English there (I'm not native).
Thank you for kind help and attention.
@Anonymous wrote:Thanks for instructions,
Answer to question - Yes, but not exactly how you guess.
Use the Offset in sketch to create the pattern path.
Do not use Sweep.
Use Rectangular Pattern command (really should be named Curved Driven Pattern (where the "curve" is often rectangular, but not required)). This comes up often enough that I guess maybe they should have created a completely different icon for curve driven patterns rather than include in the Rectangular Pattern command.
The document I linked does not replace classroom based training.
You can probably find many other examples here by searching on the terms, "curve driven patter", but first I would master basic sketching using symmetry about the origin where appropriate and learning how to create fully constrained sketches. This is similar to the actual manufacturing process of establishing machine datums, geometric and dimensional parameters.
Thank you! I appreciate the detail and helpful information you kindly gave. I will do as instructed.
Was the picture I posted something like what you were after?
I can post step-by-step instructions, but I prefer to have all the details known for the problem descrescription before going into detail on the instructions. Most new users post here one time and then disappear when it becomes apparent that they will have to do a little work.
Well thank you very much, to me the right direction is enough to start searching, I like to do 'my own homework' by me 😉
I'm already very grateful of your help, it was my second topic to this forum and at least based on the "first time video answer" I got for my previous post, I can say you are the real "Inventors" and innovators !
Thank you!
