I am trying to show a representation of a rod style belt using a feature driven pattern. I am having a problem getting the links to follow the curves of the pulleys. I would appreciate it if someone could take a look at what I have and pint out where I went wrong that I can only get it half right. Oh and I am using 2013.
Solved by johnsonshiue. Go to Solution.
I changed the layout part to make it easier to see what's going on.
Hi! It is the feature pattern occurrence orientation issue. To fix it, simply open "LSI24882-M0106 BELT LAYOUT.ipt" and edit Rectangular Pattern2 -> expand the dialog -> select Direction 1 as Orientation -> OK. Go back to the assembly and update. It should work like you wanted.
Could you try it out and let me know if it works for you?
Thanks!
2013 files
Thanks guys. I missed & misunderstood the option to orientate to direction 1.
