Inventor Forum
Feature driven Pattern
40 REPLIES 40
Message 1 of 41
CAD-One
6372 Views, 40 Replies
Can we do a Feature driven pattern in Inventor?
I dont have any parts to share, but can explain my requirement.
I have a assembly file consisting of couple of parts. One of the part is rectangular plate with a several square holes. These In the part level these Sq holes are created using a rectangular pattern.
At the assemb;y level, I want to insert a square plug (plastic Cover) that closes these square holes. I need to know if we can link this pattern to the Original rectangular pattern at the part level.
I have used this kind of feature in solidoworks & its called as Feature Driven Pattern. I need to know if this is possible here.
If so, It makes it so easy to install these covers to all the holes. & when the original hole pattern changes, the cover pattern automatically updates at the assembly level.
C1
Inventor Professional 2020
Vault Professional 2020
AutoCAD 2020
40 REPLIES 40
Message 41 of 41
Dorchester
in reply to: swalton
Vielen Dank, oops, thank you very much for your answer.
I used to work with SolidWorks until recently. In SolidWorks the equivalent to Iparts and Iassemblies are configurated parts and assemblies but then it’s not the same. Configurations in SolidWorks are “real” parts or assemblies and therefore can do all, the original ones can do.
