Inventor Forum
FEA - soft spring
1 REPLY 1
1423 Views, 1 Reply
FEA - soft spring
When soft springs are added to an assembly during analysis - how soft are they?
Can the value of these springs be found?
MES
1 REPLY 1
Would a soft spring be :
1 N/mm
0.1 N/mm
0.01 N/mm
0.001 N/mm
0.0001 N/mm
or none of the above?
When you see the soft spring message what does it mean in real terms, what's the effect on the accuracy on an assembly which requires holding together with soft springs?
Cheers
MES
