I set up a new material from within FEA Environment by double clicking materials in the browser tree then openign the styles editor. I filled in every box; Yield str, UTS, Youngs modulus etc. but there was no input for Shear Modulus.
Am I just missing it? When I generate an FEA report it lists a Shear Modulus for my material despite me not entering one..
Hi Cnoj,
We can calcuate the Shear Modulus via Young's Modulus and Poisson's ratio:
G= E/2(1+nu)
Where G is the shear modulus of elasticity (sometimes called modulus of rigidity), E is Young's modulus and nu is Poisson's ratio.
Hope this helps!
Best regards, -Hugh
Hi
WHen entering the Physical Mechanical properties of a material, I cannot change Shear Modulus.
My preference is to enter Youngs and Poisson and let Inventor use the default equation (G= E/2(1+nu)) howere this doesnot seem to work.
Here is my workflow:
Inventor Materials Library: Select CFRP.
In Document Materials use the edit icon.
Physical tab: Enter Youngs 19.3 GPa and Poissons 0.39. Shear Modulus delete. The Shear Modulus repopulates at 53000.000MPa.
To fault find, I would then enter other values of Young or Poissons but the Shear Modulus defaults to 53000.000 MPa.
Please help.
Blair, thanks for your reply.
The Shear Modulus value displayed is 53000MPa regardless of entering a variety of Young's values...so it cannot be calculated. Added to this is the results of the simulation are giving deflections substantially lower than expected so I suspect that the material properties are incorrect. 19.3GPa/(2*(1+.3) does not equal 50000MPa.
Are you saying: regardless of what is displayed in shear modulus, Inventor will use: Young's, Poisons and the calculated value?
I suspect my workflow is incorrect which is why I posted my workflow.
Pete
Blair
Thanks for reply. I also followed the recommend threads on the right side of the post and see this is a known issue and irrelevant.
I'll continue to source the error in the simulation other than Shear Modulus values.
P
I'd love to be able to just manually enter the shear modulus. I've got plenty of material data sheets that specify the shear modulus but don't give me anything to work with as far as Young's and Poisson's.
Rusty
Thank You for answers.
At first, I'm sorry for my English - self-taught person.
I'm programing now a macro for automatic export and import of material parameters to and from a .txt files and can't find the Shear Modulus like a material parameter. So You answer show up the reason. If I understand good, so it is not necessary, because in stress analysis is this parameter not used from material table, but is calculated from Young and Poisson directly at the analysis. Is it right ?
