Inventor Forum
FEA Capable to simulate a PL on a pipe?
1 REPLY 1
246 Views, 1 Reply
Hello all,
I am wondering if the FEA in Inventor 2013 is capable of simulating a pipe under a point load and at what point the pipe fails.  Its a simple 2in dia pipe supported by a vertical tube with a load of 'X' centered on the pipe.
Thanks in advance.
1 REPLY 1
cwhetten
Yes, it can do this.  But it depends on what you mean by failure.  Inventor will perform a linear analysis, so any result with stresses above the yield stress will be meaningless.  But if by failure you mean "exceeds the yield limit", then Inventor will be of use.
