So I have an assembly made up of several smaller assemblies and have constrained them in the main assembly but when I run the analysis, the interaction does not seem to exist.
An image has been displayed below, the pin should line up with the holes.
You've got constraints in the main assembly, but do you have contacts / constraints set up correctly in the Stress Analysis environment?
Rusty
