Inventor General Discussion
Valued Mentor
100 Kudos
Post 11 of 28
Re: Fastest way to create DXF of sheetmetal for lasercutter?
12-09-2009 05:24 AM in reply to: hotreneke
I do it the way you say. I dont use the right click/save as method as I usually have more than 1 part so its easier to make a 1:1 drawing of all my parts and then save as dxf for nesting in acad.
Active Member
0 Kudos
Post 12 of 28
12-09-2009 06:49 AM in reply to: hotreneke
hi, sorry tried to upload the files earlier, but wasn't able to. here's the first one.
Active Member
0 Kudos
Post 13 of 28
12-09-2009 06:52 AM in reply to: hotreneke
here is the corresponding dxf file.
*Expert Elite*
33 Kudos
Post 14 of 28
12-09-2009 07:09 AM in reply to: hotreneke
Right click on the file and select "send to compressed zip folder" and then try to attach that. I think you can only attach 1 file at a time unless the files are included in a single zip file. An the file has a max size limit of 2MB
*Dennis Jeffrey
Post 15 of 28
12-09-2009 07:58 AM in reply to: hotreneke
I think it's a max size of 1.5MB, not 2MB
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
http://teknigroup.com
Active Member
0 Kudos
Post 16 of 28
12-09-2009 08:53 AM in reply to: hotreneke
here it is
Employee
0 Kudos
Post 17 of 28
12-10-2009 11:01 PM in reply to: hotreneke
Our developer has began to investigate about this issue.
Moreover, can you change your flange's bend transition to avoid this issue?
the step is as below:
1.open your part file
2. edit the flange feature one by one
3. change the bend transition in the bend page to be "Intersection"
*Expert Elite*
2,129 Kudos
Post 18 of 28
12-11-2009 05:49 AM in reply to: hotreneke
>here it is
This doesn't address your immediate problem - but I thought you might be interested in how I might model your part - it looked to me like you are doing too much work. (see attached)
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Active Member
0 Kudos
Post 19 of 28
12-11-2009 09:52 AM in reply to: hotreneke
hi,
jacky, the solution you gave about the transition did not work out.
I saw that you guys remodeled the file. Could you please give me and idea so far of what has come up with you ?
Does it seem like a cam mistake, or is it something software related? If the first, could you please point out what is being done specifically, and if the latter when would there be an update release?
btw, thanks a lot, I am pretty much impressed by the support.
Active Member
0 Kudos
Post 20 of 28
12-12-2009 08:17 AM in reply to: hotreneke
hi, aparently the guys in product development tell me the problem is still there, even with the file you have modeled.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
