I have a similar problem. I need to export an inventor part to dxf format, however to use it on my press brake simulation software (Vbend), instead of my lasercut. Problem is that I need to export the part with the bend lines, and the file is not usable immediately.
What happens exactly is that I turn off the layers i do no use, keep the bend lines and outer contours (I checked a video which was posted on a website to do this), and enforce the profile to polyline feature. But when i zoom in on the dxf file, the connecting point between the contour and the bend line is not accurate (bend line is actually crossing the contour). Is there a way to automatically correct this ?
This is a MAJOR issue for us, as we have to rework every single file.I have to clean it up before, which causes me a big headache, since i have to do this for around 300 parts for each assembly (100 + assemblies). You can imagine the work.
Any help would be very very very highly appreciated (can't emphasize enough on that).
