Inventor Forum
Fasteners not updating location
2 REPLIES 2
off2board
187 Views, 2 Replies
Has anyone noticed when moving the location of a detail, the fasteners linked to it (or linked to the hole) does not move?
If I edit the insert mate and just hit okay, it corrects itself...but a bit of a pain if you have 20 fasteners.
2 REPLIES 2
mcgyvr
in reply to: off2board
using any "adaptive" stuff?
Does using "rebuild all" work instead of having to edit each constraint? Or what about the "local update" button (lightning bolt I think still) in the quick access toolbar.
I usually just use the update button.
off2board
in reply to: mcgyvr
Ah yes.  Rebuild All does the trick.
(local update...aka lighting bolt) isnt lit up at this point.  But rebuild is doing the trick.  Thanks!
