Inventor General Discussion
Dan.M
Message 21 of 26 (286 Views)
Re: iLogic to Select all closed profiles in a sketch
01-31-2012 05:36 AM in reply to: Curtis_Waguespack
Works very well.
Nice one.
Dan
Curtis_Waguespack
Message 22 of 26 (273 Views)
01-31-2012 08:16 AM in reply to: mcgyvr
:smileyembarrassed:
lol mcgyvr,
It was your mention of silk screens that inspired me to throw that together, as I've encountered that exact challenge in the past. Someone else mentioned engraving logos, and I've run into that as well.
Up until I read those two examples of how this might be used, I was thinking as JDMather and jeanchile were that this request was coming from a poor workflow. So I'll throw in a caution to new users not to try and use this or anyother iLogic as a shortcut to good technique:
http://inventortrenches.blogspot.com/2011/03/inventor-101-simple-fully-constrained.html
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Valued Contributor
fakeru
Message 23 of 26 (260 Views)
01-31-2012 10:04 AM in reply to: Curtis_Waguespack
Thank you very much!:smileyvery-happy:
Anyway, here is a real example.
This is an imported sketch from Autocad:
http://img826.imageshack.us/img826/4955/captureven.jpg
These are the columns of a building:
http://img804.imageshack.us/img804/9748/microdosinglevel1.jpg
I choose to make them in one extrude feature.
Regards
Alexandru
AIP 2014
Windows 7 x64
Dell Precision T7400 Intel(R) Xeon(R) CPU X5472 @ 3.00GHz (4 CPU's), 8Gb RAM, NVIDIA Quadro FX 5600 1536MB GDDR3
mcgyvr
Message 24 of 26 (224 Views)
02-07-2012 08:01 AM in reply to: Curtis_Waguespack
Curtis_Waguespack wrote:
:smileyembarrassed:
lol mcgyvr,
Again..Curtis.. I love you.. Just had to do a very large silkscreen with tons of profiles to pick.. For giggles I did it manually first and it took 4 min 18 seconds to pick them all. Then I undid that and tried your ilogic rule.. Took ONLY 11 seconds for the rule to run/extrude all the profiles. Amazing...
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Curtis_Waguespack
Message 25 of 26 (165 Views)
08-21-2012 10:21 AM in reply to: Curtis_Waguespack
Hi Inventor users,
By request I've added a couple of other versions of this iLogic rule at this link. One version  uses the Through All method and automatically cuts all open profiles through all, bidirectionaly. The other use the To Next method to extrude.
http://inventortrenches.blogspot.com/2012/03/ilogic-to-select-all-of-closed-profiles.html
I hope this helps.
Curtis
mcgyvr
Message 26 of 26 (145 Views)
08-21-2012 11:19 AM in reply to: Curtis_Waguespack
Curtis..I still love you for this.. I use it all the time.. :heart:
Windows 7 64 bit
