Inventor Forum
Failure to Sweep on Path
7 REPLIES 7
Message 1 of 8
487 Views, 7 Replies
Hello, Me and my Co-Worker have been struggling to sweep this Donut Shaped Sketch Across these 11 Paths Successfully.
Can someone Help us figure this out?
Thanks.
7 REPLIES 7
Message 2 of 8
pgcust
Do you need one solid body or 11 individual bodies?
What version of Inventor?
Chris
Message 3 of 8
in reply to: pgcust
Originally we were attempting for 1 Solid Body. But We Hadn't Considered Multiple Bodies.
Is it possible to do both?
Inventor 1014
Message 4 of 8
pgcust
How about this
Message 5 of 8
JDMather
How are you going to manufacture that?
It doesn't make sense to me that you would sweep as a "donut" sketch rather than Sweep all and the Shell (not that that is going to work either in 2014).
Message 6 of 8
in reply to: pgcust
Is it Possible to do this without the use of multiple bodies?
Message 7 of 8
in reply to: JDMather
We tried this. It didn't work.
Message 8 of 8
4donwan4
There is not a way to achieve what you would like unless you use multi bodies. Eventually you could get surfaces for all 11 and then start with the cutting and stitching commands to get a outline of the desired part. Then a sculpt command could be used. This is just a theory to get to the desired result but there is a lot of edit time prior to using the Sculpt command.
Don
