Hello, Me and my Co-Worker have been struggling to sweep this Donut Shaped Sketch Across these 11 Paths Successfully.
Can someone Help us figure this out?
Thanks.
Originally we were attempting for 1 Solid Body. But We Hadn't Considered Multiple Bodies.
Is it possible to do both?
Inventor 1014
How are you going to manufacture that?
It doesn't make sense to me that you would sweep as a "donut" sketch rather than Sweep all and the Shell (not that that is going to work either in 2014).
There is not a way to achieve what you would like unless you use multi bodies. Eventually you could get surfaces for all 11 and then start with the cutting and stitching commands to get a outline of the desired part. Then a sculpt command could be used. This is just a theory to get to the desired result but there is a lot of edit time prior to using the Sculpt command.
Don
