Inventor Forum
failed to save factory member
5 REPLIES 5
3141 Views, 5 Replies
When I try to add a particular iPart to a new assembly, IV won't let me and
gives the error 'Failed to save factory part'. What does this mean?
Kevin Wehner
724.941.9704-3019
SKC Inc.
863 Valley View Road
Eighty-Four, PA 15330
5 REPLIES 5
The very same thing just happened to me. In fact, I was logging on to post the same question. Could this be some kind of conspiriacy? Is Inventor haunted? Are we doomed? Does anyone know what this message means?
Ed
Could something be wrong with that member in the table? Have you tried setting it to that
member in the Parent file?
If you want, post it to customer files, and I am sure someone will be able to figure out
what might be wrong.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Kevin Wehner" wrote in message
news:BFF1E37943B2055652BD10670B77FA2D@in.WebX.maYIadrTaRb...
> Kevin Wehner
> 724.941.9704-3019
> SKC Inc.
It happened with any version set to default. I ended up removing the iPart
data and then making it an iPart again, just carrying over less information.
Now it works.
I'm not sure what the deal was. I am surprised that my mouse survived the
ordeal.
Kevin Wehner
724.941.9704-3019
SKC Inc.
"Kent Keller" wrote in message
news:3ADDBBF2957586B4DDC4990C3D922622@in.WebX.maYIadrTaRb...
setting it to that
to figure out
> Kent
> Assistant Moderator
and
> > Kevin Wehner
> > 724.941.9704-3019
> > SKC Inc.
Go to the folder delet the ipt files generated by the factory and again righ-click on you factory table re-generate the files.
I had the same problem spend the whole day wasting my time and then I came up with this solution.
eljoseppo
Didn't work in my case.
I removed all whitespace (like " ") in the file name and it worked.
