Inventor Forum
Failed to load Library at ... Problem with Material Libraries Inventor 2014
4 REPLIES 4
adenobel
3700 Views, 4 Replies
When I change to an other project the Material Libraries fail to load. When I go to the Libraries a yellow triangle is shown. (Failed to load Library at ....)
The Library lost connection en with the Right Mouse Button I can connect againg to the Library. Every Time I switch to an other project I have to connect again. When I close and reopen Inventor the problem is also resolved. Does anybody know how to resolve this problem?
Using Inventor 2014
Thanks in advance
4 REPLIES 4
adenobel
in reply to: adenobel
Solved the problem. In one project the path of the custom library was a mapped drive like I:\Prog... While in the other project the server name was used like \\NL-DC02\Data\Prog ...
Inventor does not like that. Changed both project files to the mapped drive and the problem is gone.
Nougatti
Same issue in 2016, and same solution solved it 🙂
The same still exists in Inventor 2018.
I would like to add a short comment to this issue.
  • Please solve this problem or
  • Please inform the user when the project file is switched and therefore the  Library is not loaded.
  • And also Please inform the user when the Library is not loaded in general.
This will solve many material and color style issues within Inventor and Vault.
I have added an Idea in the Idea-station for this issue:
https://forums.autodesk.com/t5/inventor-ideas/inform-inventor-users-when-library-files-are-not-loade...
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Arthur Knoors
