When I change to an other project the Material Libraries fail to load. When I go to the Libraries a yellow triangle is shown. (Failed to load Library at ....)
The Library lost connection en with the Right Mouse Button I can connect againg to the Library. Every Time I switch to an other project I have to connect again. When I close and reopen Inventor the problem is also resolved. Does anybody know how to resolve this problem?
Using Inventor 2014
Thanks in advance
Solved by adenobel. Go to Solution.
Solved the problem. In one project the path of the custom library was a mapped drive like I:\Prog... While in the other project the server name was used like \\NL-DC02\Data\Prog ...
Inventor does not like that. Changed both project files to the mapped drive and the problem is gone.
The same still exists in Inventor 2018.
I would like to add a short comment to this issue.
This will solve many material and color style issues within Inventor and Vault.
I have added an Idea in the Idea-station for this issue:
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Arthur Knoors
