Hi
I want to create a hole approx 586x586mm. But every time i try inventor respond with "The attempted operation did not produce a meaningful result" If i do a slightly smaller hole it will work, but that is not what i want...
And i run Inventor 2014
Hi and welcome to the forums!
First thing you should wonder about with the way you're making that cut is if it's possible to do it like that in actual production.
I'd imagine it's going to be cut in the flat state, so you should either use "cut across bend" or "unfold' and "refold".
I did the latter in the attached file, hope you can figure out what is different to your approach.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
