Inventor Forum
factory update
16 REPLIES 16
Message 1 of 17
1272 Views, 16 Replies
factory update
I can't create a dwg from an assembly because it's telling me that "The factory must be updated before views of it's members can be used".  What does this mean and how do you update the factory???
16 REPLIES 16
Message 2 of 17
mcgyvr
Open the iassembly. Do a rebuild all then save then regenerate the members.
Message 3 of 17
in reply to: mcgyvr
I dont' have any iassemblies........
Message 4 of 17
mcgyvr
Factory/members means you either have an iassemby or iparts are being used in that model. Check again.
Message 5 of 17
in reply to: mcgyvr
patvenetucci, look in the top position of your browser of the part you are working on. I would expect there to be a checkerboard icon and the term Table there. This indicates that you have a part that has been made into an Ipart. This is essentually multipul parts linked in a table form. You may have to open each of the parts in the table and regenerate them.
Message 6 of 17
RSNewton59
It's a lot easier than I thought.
In the browser, expand the table folder so that all the iparts are visible, select the part you want a drawing of and using the secondary mouse button 2MB (I'm left handed so I say this to clarify) select generate files.
Hope this helps.
Message 7 of 17
JonathanKruger
Are you maybe using Factory Design utilities in Inventor? I assume the DWG it is talking about is the "Open in AutoCAD" option which is creating a DWG from the Inventor factory.
If this is the case the question is probably better suited in this section https://forums.autodesk.com/t5/factory-design-utilities-forum/bd-p/510
But I think the button you would then be looking for is below? I am not sure I have had the exact error before but it sounded like the same error. I could be way off though
If this solves your issue please mark this posting with the "ACCEPT SOLUTION".
If you like something that was said or if it was helpful, Likes are appreciated. Thanks!
Message 8 of 17
RSNewton59
in reply to: JonathanKruger
I was assuming he was using 'factory' in ipart creation as I got the same message when trying to create 'correct' DIN 835 studsScreenshot 2022-08-09 095101.jpg
Message 9 of 17
RSNewton59
Unfortuneately I'm a decade late to the party on this one!
Message 10 of 17
JonathanKruger
in reply to: RSNewton59
I may be completely wrong but with his statement about not having iassembles made me think it was specific to factory add-in, I think without a screenshot of screencast we are all kind of guessing. Let's see if he could maybe post a video of his issue?
Message 11 of 17
RSNewton59
Indeed, it may be me that is wrong.
'Factory' is a bit of a silly name for the Inventor thing.
Message 12 of 17
CGBenner
@JonathanKruger The original post was ten years ago.  I would assume that by now the original poster has moved on.  Thank you for offering your assistance!  🙂
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
Message 13 of 17
RSNewton59
in reply to: CGBenner
@CGBenner
I noticed that the OP was ten years ago, but it was the only thing that came up in my search, so on that basis I think it was relevant to reply to it - especially as I had found a solution.
How I wish the Autodesk help facility was more helpful!
Message 14 of 17
JonathanKruger
LOL, I did not see the original date it was posted but I am sure this issue is not a problem anymore for the OP. Thanks for the heads up.
Message 15 of 17
CGBenner
@JonathanKruger
Thank YOU for responding (even if it's late)... I sure HOPE the OP has found an answer by now!  😂
Chris Benner
Message 16 of 17
Hello RSNEWTON59. What did you do to resolve this problem:
Message 17 of 17
Hi Rajesh,
The warning message means the iPart factory file isn't up-to-date. Please open the iPart factory file -> Update or go to Manage -> Rebuild All. Does it work better then?
Many thanks!
Software Test Engineer
