Inventor Forum
Extrusion wont work thru whole assembly
1 REPLY 1
260 Views, 1 Reply
I have attached visualisation to explain what I mean - extrusion should cover whole assembly, however it ignores few parts on the top of the assembly. How does it happens and how can I control which parts are effected by the extrusion and which are not? Thank you for your replies!
1 REPLY 1
japike
You should be able to right click on the extrusion in the browser and select "Add Participant" then pick the components you want.  And if you want to remove a component, right click on the components listed under the extrusion in the browser and select "Remove Participant".
Peace,
Jeff
Inventor 2022
