Inventor Forum
Extrusion Enhancement Idea
8 REPLIES 8
Message 1 of 9
ad64
662 Views, 8 Replies
A great enhancement to Inventor (IMHO) would be an extrude "From" option. This option would give the ability to extrude by "Distance" but from another surface other than the sketch plane.
When modelling top down, one often has cross-section sketches with components in the cross-section that are not symmetrical about the sketch plane. You can use assymetric distance extrusion in this case, but now you have to figure out how to divide your length formula into two parts so that the right proportion falls on each side whenever the model changes to a different size.
An extrude "From"  option would work much better. Using this option you could pick the surface on which you wanted to start the extrusion and enter a distance formula. The part is now fully parametric. This option would be sort of like the opposite of the extrude "To" option except you could supply a distance for the part length allowing the part to begin at the "From" plane and stop short of the sketch plane or continue on through it an assymetrical amount.. It would also be like the "Between" option except that you would supply a distance rather than a second surface when the second surface is not readily available.
Would anyone else find this enhancement useful?  Perhaps something like this already exists and I am just not aware of how to do it.
Steve
8 REPLIES 8
Message 2 of 9
in reply to: ad64
SolidWorks has this and its great.
Message 3 of 9
nmunro
in reply to: ad64
I like it! You could use the following work around in some cases today.
  1.  Create a work plane offset from the "From" surface (gives you a distance to play with).
  2.  Use the Between option for the extrude. Between the "From" surface and the offset work plane.
You can then adjust the extrusion distance by updating the work plane offset.
https://c3mcad.com
Message 4 of 9
MingweiGao
in reply to: ad64
A good suggestion, Steve! A wish list has been logged into our tracking system and the ID is 1471675.
Steven Gao
Principal Quality Assurance Engineer
Message 5 of 9
ad64
in reply to: MingweiGao
Is there any way to check the status of this idea using the tracking number (1471615) in Ideastation or otherwise?
Steve
Message 6 of 9
MingweiGao
in reply to: ad64
Hi Steve,
This only can be checked in our internal issue tracking system and I saw it(1471675) is confirmed and still on Open status.
Steven Gao
Message 7 of 9
ad64
What does "Open" status mean? Should I also add it to Ideastation so that it can get more visibility and therefore be more likely to be included in Inventor in the near future?
Steve
Message 8 of 9
mcgyvr
in reply to: ad64
Steve
There are more than likely hundreds of "requested features" in the open status.. It means it could be in the next release or nothing will happen at all. Pretty sure that request has been submitted many times over already but other users, and we haven't seen it yet.
Message 9 of 9
Xun.Zhang
in reply to: ad64
Hi Steve,
Have you try Inventor 2018 Alpha or Beta builds? it seems your desired behavior around the corner.
Xun
