Hi! The physical screen shot is not very clear. Could you either post the part file here or use Print Screen key to take a snap shot? I would like to understand the request better.
Thanks!
Hopefully this is clearer, thank-you for looking at this.
Many thanks for the updated image! But, I have to say I still don't quite understand the design intent here. Does the profile represent the length-wise section or width-wise section of the ship? Also what unit is the dimension of 3974?
Thanks!
The flat section runs vertically in the length of the rectangle as it is a portion of the side of the hull. The curved section is the start of where the hull's side goes from flat to the part that's in the water running from the top of the hull to the bottom.
The 3974 is the length of the flat part of the side of the hull before it starts to curve.
Is something like this (see attached) what you are trying to do?
Exactly as you've done with the barge but I'd like the whole shape to be solid.
If you see the attachment, I am trying to sketch the wall of the hull with where the blue bench is being the part of the hull that starts to taper towards the bottom of the ship.
Please respond if you need more information.
Something like this?
