Inventor Forum
Extrude to dome
7 REPLIES 7
Message 1 of 8
aaron
2176 Views, 7 Replies
Extrude to dome
Hello All,
I am a very inexperienced CAD user so I'm not sure if this is a trivial question. In 2D I have some spline curve that I extrude into 3D and I want to make a "dome" with the same contour. I can't fillet it because the geometry is too complex. Is there some sort of "variable" extrude where the extrusion distance is some function?
Aaron R. Shifman
7 REPLIES 7
Message 2 of 8
admaiora
in reply to: aaron
Hi AAron,
depens on your design intent.
You can do it in many ways. Which dome?
Your fillet radious is too big?  Try reduce it.
You can use extrude..revolve..surfaces..sweep..loft...etc
But if you have no so much experience with the cad in general it would be better understand first the basis of the 3d parametric modeling.
Attached  a simple example of dome.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 3 of 8
aaron
in reply to: admaiora
Hi Admaiora,
Thanks for the quick reply, and that's exactly what I'm looking to do, except that when I filet it, I specify a full face fillet and it cannot be performed because the geometry is too complex. And I'm not quite sure how to use a revolve to accomplish this.
I have attatched a copy of my model and if it's not too much to ask would you mind breifly looking at?
Aaron R. Shifman
Message 4 of 8
JDMather
in reply to: aaron
Something like this?
Message 5 of 8
aaron
in reply to: JDMather
That's perfect,
much appreciated,
Aaron R. Shifman
Message 6 of 8
JDMather
in reply to: aaron
@Anonymous wrote:
That's perfect,
I don't think it is really "perfect".
Your Sketch did not have any dimensions - so I did not try to get perfect geometry.
Check carefully near the "pointy" end.
Message 7 of 8
markwiggs
Hey could someone please explain exactly how this was done? Im struggling on something similar over here:
https://forums.autodesk.com/t5/design-validate-document/help-with-doming-imported-dxf/td-p/6419160
Message 8 of 8
WHolzwarth
in reply to: markwiggs
2016 file is attached in the other thread
Walter
Walter Holzwarth
