Inventor Forum
Extrude To Cylindrical, Curved Body
7 REPLIES 7
Message 1 of 8
445 Views, 7 Replies
I know there are a number of posts with similar questions, but I haven't been able to find an answer for my situation.  Any help would be appreciated!
I'm trying to create a cavity on the bottom of the guitar neck for the truss rod.  In the model you can see I have a 2D sketch and a 3D sketch and neither will extrude to the curved hollow section inside the neck.
I've attached my file for review.  My customer is waiting and I am at a road block.  Please help!  Thanks in advance.
Tags (3)
7 REPLIES 7
Message 2 of 8
JDMather
What version of Inventor are you using?
Have you installed all Service Packs and Updates for your version?
Maybe what you want to do is Thicken/Offset surfaces and then Extrude-Cut up to the surfaces
or
maybe what you want to do is Split Face and then Thicken-Cut.
Message 3 of 8
JDMather
@Anonymous wrote:
... neither will extrude to the curved hollow section inside the neck.
Would that curved hollow section completely cap the extrusion, or is Sketch66 microscopically larger then the curved hollow section somewhere along the curve?
Message 4 of 8
in reply to: JDMather
JD thanks for the quick reply.
I'm using Inventor 2013.  I believe I have all updates.
In regards to the two methods you mentioned, can you please elaborate on the steps?  I'm a little fuzzy with the steps order.
Message 5 of 8
Sketch 66 is the same width as the tunnel diameter (.25)
Yes, the top of the hollowed section is the stopping point for the cut.
Message 6 of 8
JDMather
I get a slightly  different width, with the 2D sketch slightly wider than the tunnel diameter at at least one location.
Also, go to Help>About Inventor and check your Service Pack.  iProperties seems to indicate that you have not installed any Service Packs or Updates.
If I Offset the slot loop .0001 to the inside to make it smaller - it Extrude-cuts fine.
The problem with the Sweep23 is that you did not create the Sketch63 profile on a plane perpendicular to the start of the Sketch64 path.
But assuming that hole is drilled from the end - you did correctly.
I would simply use the insignificant offset solution suggested above (cannot measure in real world anyhow).
Message 7 of 8
JDMather
Or even better solution -
Extrude Sketch64 midplane as a Surface and then Extrude-cut to the surface.
Then simply turn off the visibility of the surface body.
Message 8 of 8
Perfect! JD thanks a lot for taking the time to answer my question and being so thorough with pictures. You saved my butt! Thanks again.
