post the part.. chances are you don't have one of the rectangles fully closed or something like that..
Or it might not like that font..have you tried a different font.. (like start with arial font and see if it still does it)
Is constraint persistance/inferrence turned on?
No offense, but that youtube video is hard to follow. Screen shots would be better
I agree with what has been said. My thoughts are to do a process of elimination. Try extruding the
rectangles first and see of they will go. If not then there is the start of your issue.
Then work on each character at a time till you get the culpret.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
The Extrude command will work for the rectangular boxes but you will need to use the Emboss command for the text.
@Blair wrote:The Extrude command will work for the rectangular boxes but you will need to use the Emboss command for the text.
I extrude text all day long. Unless there is something I'm not seeing in the video there is NO need to use emboss for text.
I suspect the "Text" is throwing up the error. Yes some font's extrude fine but in this case I would use the Emboss to solve the error rather than going through each text and each character to find the offending item.
