Inventor Forum
Extrude/Revolve on a given angle around a cylindrical body
4 REPLIES 4
MBixler
1260 Views, 4 Replies
I am really struggling in trying to revolve around cylidrical body on a specified angle. I understand the degrees of rotation angle, but i am looking to revolve or extrude a certain shape for the length of the shaft.  Like trying to make a coil or a set of threads.
Can anyone help? I have tried to use sweep but sweep doesnt work with two sweep lines.
4 REPLIES 4
sam_m
in reply to: MBixler
If you are trying to create a rotation along a length for a coil or to cut a thread try looking at the "coil" command.
hope that helps, Sam
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
LT.Rusty
I've always found that the Coil feature works quite nicely for making, well, coils.
YMMV, though.  The button is above and to the right from the sweep feature.
Rusty
MBixler
in reply to: LT.Rusty
I do not seem to have that coil feature for whatever reason on my tabs?
JDMather
You are in the wrong forum - you are running Inventor Fusion, not full-featured Autodesk Inventor.
You should be over here http://forums.autodesk.com/t5/Inventor-Fusion/bd-p/370
