Can you post what you have?
In order to post here, the file must be zipped,
and under 1.5MB in size. If the file is larger than that, then post the
files at
this location:
You can post the file as is to ftp.interlancentral.com -
month>2007
folder.
Create a network place OR use Internet Explorer to post.
In IE, Select File > Login
username: newsgroup password: Inventor1
or use this link: ftp://newsgroup:Inventor1@interlancentral.com
This is the location that the Autodesk newsgroups use to post large files.
Keep in mind that it is a public site, just like this newsgroup.
Full information is located in the FAQ that is posted here weekly by Kent
Keller.
Let us know in the this newsgroup when you posted it, and the name of your
file.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP3, AIP 2008 SP1
HP zv5000 AMD64 ( modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
wrote in message news:5680338@discussion.autodesk.com...
I am relatively new to Inventor, using 2008. My goal is an assembly with a
short cylinder on the XY plane with slats across to form a baffle. I want
each slat (sketched on the XZ plane) to be a separate part. There will
ultimately be a cooling tube running through all the slats. I have been
unable to get the sketch to extrude out to the cylinder for the elliptical
ends. Can't select the inside surface of the cylinder. Is this possible?
Thanks.
