Inventor Forum
EXTRUDE DOES NOT WORK - NEED HELP
8 REPLIES 8
Message 1 of 9
1059 Views, 8 Replies
Hi All,
My name is Hiandy and I am using Inventor 2014.
I have a situation with "extrude feature". Please take a look to those attached files. There are 3 beams and each has length 2000 mm. I want to extrude through all beams. But failed.
My questions is why I can not do the extrude from beam 4A to beam 4B in an assembly environment?
I would really appreciate for your help.
Thank you.
Hiandy
8 REPLIES 8
Message 2 of 9
admaiora
Hi Hiandy,
try just using the option Join, an choosing an extent solution correct for you ("to" for example).
I hope that it can helps you.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 3 of 9
JDMather
Why are there 3 different parts? Aren't at least two of them the same?
Message 4 of 9
in reply to: admaiora
Hi Admaiora,
Thank you for you reply. I will try first your advice. Hope it will give what I want.
Hiandy
Message 5 of 9
JDMather
@Anonymous wrote:
Hi Admaiora,
Hiandy
How can that logically work?
The Extrude-cut is in part BEAM 4A, at the part level, not the assembly level.
If you walk out to the shop floor and cut one part the cut does not cut another part unless it is done at the assembly level.
You have to use the same logic as the real world.
If you want this to be three instances of an identical part - place 3 instances.
If you want to cut all three after they are assembled - then cut in the Inventor assembly after they are assembled.
If you want the cut before they are assembled - then you already have that - simply place two more instances.
Message 6 of 9
in reply to: JDMather
Hi JDMather,
Thank you for your response. Let me see whether I can understand and follow your advice.
See you later.
Hiandy
Message 7 of 9
Hi JDMather,
I still can not get the extrude (cut) from end to end of all 3 beams. I already followed your instruction: to do it in assembly environment after assembly. What I did was to create a sketch on the face but I could not apply 'Project Cut Edges' to that face (see the attached file).
Will you help me by showing ways or methods (step by step) of how to 'cut' (extrude) those all three beams at a time.
Thank you.
Hiandy
Message 8 of 9
JDMather
@Anonymous wrote:
Hi JDMather,
Hiandy
There is no logical reason to "Project Cut Edges".  I am confused about where you got that instruction?
I did not open your *.doc file to see an image you could have attached directly here.
Message 9 of 9
HI JDMather,
Thank you for your reply. Applying "Project Cut Edges" is not part of your instructions. It was my move which I thought it could be able to execute "Extrude"feature in assembly environment (this part is from your instruction).
If you said that "Project Cut Edges" is not a logical reason thing to achieve what I want, then as previously requested, would you kindly let me know how to cut ('extrude') all three beams in an assembly environment?
Please find all related files on attachment.
Awaiting to your reply.
Thank you.
Hiandy
