Thanks Al, works here too. I don't like the hoops that I have to go through
to do this. It should be in the context menu when I enter the depth.
"AlEtzkorn" wrote in message
news:6119499.1073571641859.JavaMail.jive@jiveforum2.autodesk.com...
> Can you get it if after extruding, you Show dimensions, and highlight the
depth there, then select Dimension Properties, you can set the tolerance
there.
> I just tried it and it works on my end
> Al
