Inventor General Discussion
Active Member
Emil.Lewandowski
Message 11 of 16 (324 Views)
Re: Extrude Cut Multiple Solids
01-15-2013 10:24 PM in reply to: chrisrodway
Maybe I missunderstod this thread, my english is not the best :smileywink:. But as an answer to the first post, one cut thru multiple solids, i've attached an example file. Regards Emil
*Pro
sbixler
Message 12 of 16 (309 Views)
01-16-2013 07:03 AM in reply to: Emil.Lewandowski
Interesting-- the attached file has two disjoint solids, and I am able to extrude cut through both solids without any issue.  But in the example file that Chris (OP) posted, I can't do it.  What's the difference?
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Active Member
Emil.Lewandowski
Message 13 of 16 (300 Views)
01-16-2013 07:23 AM in reply to: Emil.Lewandowski
It also works in the file that chris posted. If deleting the cut outs, it works fine to do just one new thru both solids.
Even with the original sketch and workplane. But I can't figure out why it doesn't work with the first original feature.
/Emil
Valued Contributor
chrisrodway
Message 14 of 16 (295 Views)
01-16-2013 07:27 AM in reply to: Emil.Lewandowski
/Emil
Thanks Alot for your input guys out of intrest Emil which original feature that its not working with?
Chris
Design Engineer
Sheffield UK
Cheers
Chris Rodway
Design Engineer
Sheffield, UK
Active Member
Emil.Lewandowski
Message 15 of 16 (289 Views)
01-16-2013 07:41 AM in reply to: chrisrodway
The one called "CUT ONE" somehow doesn't seem to work properly.
Valued Contributor
chrisrodway
Message 16 of 16 (279 Views)
01-16-2013 08:01 AM in reply to: Emil.Lewandowski
Thanks for the help guys
Ive just look into it and for some reason if you edit the feature it doesn't let you selected multiple solids, you have to delete it and make a new extrusion. Don't know why
Cheers Everyone
Chris
Design Engineer
Sheffield,UK
Cheers
Chris Rodway
Design Engineer
Sheffield, UK
