Inventor General Discussion
Valued Contributor
chrisrodway
Message 1 of 16 (1,662 Views)
Extrude Cut Multiple Solids
1662 Views, 15 Replies
01-15-2013 07:05 AM
Is there any way in inventor to use one extrude cut feature on two different solids at the same time?
If this is possible I think it would make life a lot easier
Cheers
Chris
Cheers
Chris Rodway
Design Engineer
Sheffield, UK
Maybe I missunderstod this thread, my english is not the best :smileywink:. But as an answer to the first post, one cut thru multiple solids, i've attached an example file. Regards Emil
It also works in the file that chris posted. If deleting the cut outs, it works fine to do just one new thru both solids.
Even with the original sketch and workplane. But I can't figure out why it doesn't work with the first original feature.
/Emil
Thanks for the help guys
Ive just look into it and for some reason if you edit the feature it doesn't let you selected multiple solids, you have to delete it and make a new extrusion. Don't know why
Cheers Everyone
Chris
Design Engineer
Sheffield,UK
JDMather
Message 2 of 16 (1,660 Views)
Re: Extrude Cut Multiple Solids
01-15-2013 07:09 AM in reply to: chrisrodway
Can you post an example file where this would be useful?
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Valued Contributor
chrisrodway
Message 3 of 16 (1,647 Views)
01-15-2013 07:36 AM in reply to: JDMather
When designing slat tools what we use to manufacture parts. I generate the part to the form of a scanned surface and create the slats.
Then I make the top and bottom tool different solids for export etc. The tools still have some features the same and I thought it would be easier to do it in one feature. Other CAD packages let you do this I thought Inventor would also. The main reason for this is i am trying to automate this design process using ilogic snd its complaining about which solid to cut.
My example file is a made up part to protect my employers manufacturing techniques.
Thanks for the interest and reply
Chris
Cheers
Chris Rodway
Design Engineer
Sheffield, UK
JDMather
Message 4 of 16 (1,635 Views)
01-15-2013 07:48 AM in reply to: chrisrodway
If I understand the problem - it looks like you want this to be 30 solid bodies.
I don't know of an easy way to do that in Inventor.
Sounds like a good suggestion - an option to make all disjointed solids into individual solid bodies.
http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
Easiest current solution I can think of is Extrude To the surface(s) multiple times setting New Solid each time.
Another option might be to do the master as one (or more) disjointed solids and then Derive Component 30 times as surface body and then Sculpt the desired solid in each of the 30 derived files.
Active Member
Emil.Lewandowski
Message 5 of 16 (1,622 Views)
01-15-2013 08:16 AM in reply to: chrisrodway
Spoiler
If you make it so the cut goes from the side, first thru one of the solids, it works fine with one feature only.
Just choose both solids to be edited.
/Emil
JDMather
Message 6 of 16 (1,613 Views)
01-15-2013 09:10 AM in reply to: Emil.Lewandowski
Emil.Lewandowski wrote:
Spoiler
/Emil
Can you post example ipt file?
LT.Rusty
Message 7 of 16 (1,599 Views)
01-15-2013 11:18 AM in reply to: JDMather
Can't post the files because they're proprietary, and we haven't brought the product to market yet, but in my application for this issue I've got an injection molded part that will be molded in a tool that's made up of three separate core / cavity sections that are stacked on top of each other.  In order to make different variants, one or more of the core / cavity sections can be swapped out.  As a result, I've modelled the part as 3 separate solids, derived them into individual parts and put them into an iAssembly so that I can show any of the possible combinations mold parts to make the item.
There's a couple features that start in one mold section and are carried through into another.  Bosses, slots, etc.  It would be really great to be able to cut a slot through both solids in one feature, rather than having to cut one at a time.
___________________________________________________________
Product Design Suite Ultimate 2013, 2014, 2015
Workstation: i7-4770k / ASUS Z87-Pro / 16GB / 250 GB SSD / 1 TB HDD / 3 TB USB3 HDD / Radeon R9-270X 4GB
Laptop: Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
JDMather
Message 8 of 16 (1,592 Views)
01-15-2013 01:02 PM in reply to: LT.Rusty
Wait, wait, hold on, wait....  ...the OP already posted the problem file.
Can you demonstrate with the technique Emil suggested how that would solve the OP's specific problem.
That is what I am interested in.  I never questioned the usefulness - in fact the OP's problem attached here is a very very good example of why we should be able to easily make multiple multi-body solids.
LT.Rusty
Message 9 of 16 (1,586 Views)
01-15-2013 01:06 PM in reply to: JDMather
JDMather wrote:
Wait, wait, hold on, wait....  ...the OP already posted the problem file.  (and that isn't an accurate quote of what I wrote)
I think we might be looking at different questions.
1.  Someone posted a question about how to extrude / cut through multiple solid bodies in a single operation.
2.  You posted a question looking for a part file where that would actually be a useful technique.
3.  I responded describing a situation where I would find it useful to extrude through multiple solid bodies in one operation.
And yes, that was an accurate quote of what you wrote.
JDMather
Message 10 of 16 (1,584 Views)
01-15-2013 01:08 PM in reply to: LT.Rusty
Oops, you are right.  I thought you were the one who posted a "solution" without example.
Time for me to go home.
