Inventor General Discussion
tvernonbaker
Message 1 of 4 (1,580 Views)
Extrude Cut from 3D Sketch (or something like it)
1580 Views, 3 Replies
01-09-2013 09:54 AM
I know my subject is somewhat mis-named, because I gather that you cannot really extrude from a 3D sketch, however I am looking for a way to accomplish what extruding a cut from a 3D sketch would accomplish.
The problem is this: I have a simple 2D sketch that I've projected onto a curved surface (imagine a square projected onto the outside of a hollow cylinder). Now that I have a 3D sketch on the surface of the cylinder, I want to use that sketch as a "cookie cutter" through one wall of the cylinder.
If I were to simply extrude the cut from the 2D sketch, the "cookie" is wider at the edges than at the center. I want the cut to be perpendicular to the projected 3D sketch at all points.
I've attached a simple example that illustrates my problem.
Can anyone help? Thank you in advance!
Split and Thicken-Cut
Emboss might also be a solution.
JDMather
Message 2 of 4 (1,577 Views)
Re: Extrude Cut from 3D Sketch (or something like it)
01-09-2013 10:02 AM in reply to: tvernonbaker
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
tvernonbaker
Message 3 of 4 (1,571 Views)
01-09-2013 10:10 AM in reply to: JDMather
Thanks!
New Member
Desolationism
Message 4 of 4 (978 Views)
12-03-2013 12:57 PM in reply to: JDMather
I know this is old, but good god, you just saved me so much time.  We do a lot of odd shape and transition HVAC style ducting, this saves my life!
Thank you, thank you, thank you!
