I have an imported stp file 10' long hollow cylinder surface body. I would like to remove 3' from one end. How can I accomplish this?
Jerry
Solved by JDMather. Go to Solution.
Sketch line and Trim Surface.
Tried that with this reply "Cutting Tool does not cut any surfaces".
I tried all I could find in Help. Forum is my last resort.
I'm using 2014.
Attach your file here and end all doubt.
I tried but file too large.
Trim works fine on new surface ipt, but not on this imported stp file "Could not trim. The selected component has no surfaces."
I'm using 2014
J
Find the red End of Part marker.
Drag the red EOP above the feature(s) in the browser - hiding all geometry.
Save the file with the red EOP in this rolled up state.
Right click on the filename and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here, or if still too large, to A360.
A360 (Autodesk 360) is a cloud storage drop-box.
Upload
Make public
Generate a url
Post url to download here.
I'm on the east coast.
It is only 5:30? Still a good 2hrs to go to quiting time?
http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf
