Inventor Forum
Extrude / Cut a surface feature
11 REPLIES 11
Message 1 of 12
5470 Views, 11 Replies
I have an imported stp file 10' long hollow cylinder surface body. I would like to remove 3' from one end. How can I accomplish this?
Jerry
11 REPLIES 11
Message 2 of 12
JDMather
Sketch line and Trim Surface.
Message 3 of 12
in reply to: JDMather
Tried that with this reply "Cutting Tool does not cut any surfaces".
I tried all I could find in Help. Forum is my last resort.
I'm using 2014.
Message 4 of 12
JDMather
Attach your file here and end all doubt.
Message 5 of 12
I tried but file too large.
Trim works fine on new surface ipt, but not on this imported stp file "Could not trim. The selected component has no surfaces."
I'm using 2014
J
Message 6 of 12
JDMather
Find the red End of Part marker.
Drag the red EOP above the feature(s) in the browser - hiding all geometry.
Save the file with the red EOP in this rolled up state.
Right click on the filename and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here, or if still too large, to A360.
Message 7 of 12
Still too large.
A360?
Message 8 of 12
JDMather
A360 (Autodesk 360) is a cloud storage drop-box.
Upload
Make public
Generate a url
Post url to download here.
Message 9 of 12
Message 10 of 12
On east coast and ending my day. Thanks for the help. Tomorrow.
J.
Message 11 of 12
JDMather
I'm on the east coast.
It is only 5:30?  Still a good 2hrs to go to quiting time?
http://a360.co/104pzEM
http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf
Message 12 of 12
Yes, but I'm moving on to new employer next week. So, I'm only taking half days for this week.
We believe we have found a solution to the problem I posted. It lays in setting the options correctly when opening the stp. I'll carry it further today to make sure. Thanks for help, kudos!
Jerry Storella
Engineering Department
Dynamic Aviation
540-828-6070, ext. 3789
