Inventor General Discussion
Active Contributor
VeronicaSmith5891
Message 1 of 4 (389 Views)
Extrude all Projected Geometry automatically?
389 Views, 3 Replies
02-07-2013 10:36 AM
I have looked thru the forum and didn't see this question anywhere.  Many times I have to make mounting holes on large assemblies that have a lot of holes to project and extrude.
Is it possible for the Extrude command to pick all Projected Geometry automatically?  If it looked only specifically for only projected geometry?  It would save so much time instead of having to pick every single projected geometry hole to extrude.
Thanks!
We project in from the assembly, select all, change to construction lines and centre points, then run the hole tool.
This auto-selects all the centre points and voila! Done. If you need to control the size of the holes you can cross link parameters between the part and assembly.
Curtis_Waguespack
Message 2 of 4 (386 Views)
Re: Extrude all Projected Geometry automatically?
02-07-2013 10:44 AM in reply to: VeronicaSmith5891
Hi VeronicaSmith5891,
Here is a simple iLogic rule that I use to do this:
http://inventortrenches.blogspot.com/2012/03/ilogic-to-select-all-of-closed-profiles.html
I just set any profiles that I don't want to extrude to use construction lines, so that Inventor won't pick them up.
Here's another good tip for this sort of thing:
http://inthemachine-autodesk.typepad.com/blog/2010/08/embrace-the-intersect.html
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Active Contributor
IS200
Message 3 of 4 (361 Views)
02-07-2013 02:27 PM in reply to: VeronicaSmith5891
Active Contributor
VeronicaSmith5891
Message 4 of 4 (310 Views)
02-14-2013 09:35 AM in reply to: IS200
This worked perfect!  Thanks so much!
