This is similar problem as in your previous post - Exporting to FAI Report. There is no command that can do that but it is possible to achieve this using some sort of script as described in Exporting to FAI Report. You can export list of dimensions to csv file and then create general table using exported csv file on separate sheet. To update table with dimension you need to re-export dimensions to csv file again.
Hope this helps
Stanislav Hutnan
Inventor Development
I just found out about a product called SolidWorks Inspection and it seems it works with other softwares than SolidWorks too. Does Autodesk have anything close to that? I think most users can find use for it!
We would also like a product that works like Solidworks Inspection for Inventor. You can use Ideagen inspection to pull dimension off of a PDF but it uses OCR which isn't very reliable.
