Inventor Forum
Extract Multi Sheet Drawing to Single Sheet Drawing
5 REPLIES 5
akhidrosyidi
542 Views, 5 Replies
hi all,
does anyone know how to convert multi sheet drawing to single drawing ( mono drawing part) and use model (ipt / iam) filename for naming drawing file name..
for example i have existing file project structure like this.
model
A.iam
|---A1.ipt
|---A2.ipt
|---A3.iam
     |--A31.ipt
     |--A1.ipt
Drawing
A.idw ==> drawing filename
|--sheet1 ==>A.iam
|--sheet2 ==>A1.ipt
|--sheet3 ==>A2.ipt
|--sheet4 ==>A3.iam
|--sheet5 ==>A31.ipt
|--sheet6 ==>A1.ipt
my problem is, how to extract all sheet to singgle file every sheet like structure below
A.idw
|---A1.idw
|---A2.idw
|---A3.idw
     |--A31.idw
     |--A1.idw
daily works with :
Autodesk Inventor Profesional 2014.
AutoCAD Mechanical 2014.
Autodesk Vault Profesional 2014.
5 REPLIES 5
-niels-
in reply to: akhidrosyidi
Not sure i fully understand, but you could always make copies of your multi-sheet drawing and just delete the sheets you don't need in those copies.(?)
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
akhidrosyidi
in reply to: -niels-
your are right niels,
i can copy and paste each sheet to new drawing template and dellete unused sheet, but this is a borring jobs if i do for a hundred drawing.
is there another method to do this jobs?
daily works with :
mrattray
You could try writing a macro to do it.
Mike (not Matt) Rattray
akhidrosyidi
in reply to: mrattray
that's the idea, but i don't know how to access this object.
1.copy sheet==> 2.open new idw template ==> 3.paste sheet in this file ==> 4.dellete unused sheet ==> 5.get data from first view ==> 6.save idw file with partnumber from first view..
 I don't know how to access and manipulate this object especialy on step 1-3.
daily works with :
I know Im ressurecting an old post but I'm wondering if you ever found a solution to this as I'm looking to do the same thing.
