Inventor Forum
extra shard of material on extrude, cutting
4 REPLIES 4
205 Views, 4 Replies
I have done an extrude, cut, and ended up with a very thin shard of material
where there was none before. This seems strange, if I had made a mistake
with the sketch or the extrude command, you would think it just would not
have cut enough away? Any one seen this before, work around? I'm afraid
that if I do an stl file of this, it may be hosed.
Mike
4 REPLIES 4
Sometimes if you just draw your sketch to the edge of a part it leaves this
cut. If possible extend the sketch past the edge of the part. If you can
post it to CF I'll take a look.
Sean Dotson, PE
http://www.sdotson.com
remove all #s from email
"Mike Grunwald" wrote in message
news:5EFA51338DECAA062502D6C3B39423BC@in.WebX.maYIadrTaRb...
material
> Mike
it is posted
Since the sketch that makes up the last extrusion is made of two parts and
the projected geometry is on a curved surface, it looks like there is a bit
of area not being cut. But that still doesn't explain why it extends like a
flag past the edge of the part. Weird. By playing with the cut you might
be able to get rid of it (I was but I don't know your design restrictions).
I'd send this one into Autodesk for them to take a look.
Sean Dotson, PE
news:f11e581.1@WebX.maYIadrTaRb...
> it is posted
thanks sean. I was able to get rid of it, by deleting projected geometry
and drawing lines and arcs to replace.
mike
