OK, I'm back on custom Sheet Metal templates again.
I've got pretty mcu everything all set and ready to go live with the template. All custom styles are created and iLogic rules are set and tested.
But the Sheet Metal Rule for all this is set to "Local", if I understand things correctly, this has to be set to "Library"...correct? Or will this be set once I publish the template file?
