I am using Autodesk Inventor 2014
I have an assembly with many parts, is there anyway to select some of those parts and only export the selected parts to another assembly?
Thanks!
Solved by karthur1. Go to Solution.
Not quite sure I follow you, but you can do what you want with copy/paste or demote.
To use copy/paste, open the assembly and select the parts you want in the other assembly, right clk choose "copy". Now go to the other assembly, right click and choose "Paste". In 2014, the constraints will be held between the items that you copied.
